Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
I guess it must be form wound. If it were random wound, it would have slots shaped more like a trapezoid (to allow uniform tooth width).Is it random wound for form wound?
For example you could wrap paper completely around a coil side before placing it in the slot. (probably couldn't wrap both coils in the same sheet). That is not a choice for normal semi-closed slot where you have to feed conductors in through the narrow gap at the top, but would be an option for this rectangular slot. Again the idea is to try to make the slot section winding a little mechanically stronger. vpi of course even better.If for some reason, you can't do that, at least make sure the slot liner wraps all the way around and perhaps tie it, rather than wrapping the slot liner around just far enough to meet the top stick... a litle bit of insurance against the possibility of that topstick coming out. But vpi would be better imo.
Actually, I can think of another reason why open slots without magnetic wedges may be less tolerable on small motors than large motors: if you compare length of the flux path (for a given pole) in iron between large motor and small motor, there will be a dramatic difference between large and small motor... but if you compare flux path in air there is not much difference. So airgap is relatively larger on small motors and has a biger impact on power factor. The mag wedges are a means to decrease the effective airgap (via the Carter factor) and improve the power factor slightly.I think the harmonic considerations are similar for random wound as for form wound, but the small random wound motors tend to have smaller number of stator slots and rotor bars, so the open slot construction tends to be less tolerable for the small motors. (At least, that's the only reason I can come up with the random wound motors with open slots would typically require mag wedges, when most form wound motors with open slots do not.)
