Hi Gurus,
I am designing an agitator which can agitate an 3000lb object linearly at about 180 rpm. I will use a 10 to 1 gear ratio gear box to achive 180 rpm requirement. And, I will use an VFD drive to alter the speed of the agitation (from 60 rpm to 180 rpm).
I have a few questions and hope you can help me.
1. Is it true that VFD can only work with inverter duty motor (not the regular AC motor), what will happen if I use a regular AC motor with VFD drive?
2. What is the function of VFD? VFD will make the torque independent of the speed? meaning the VFD will try to maintain the speed (no matter how small the speed is) and enable the motor to provide enough torque (up to the breakdown torque/full-load torque??) to run the system at the same time. In other word, the full-load torque of the motor will be kept the same. what about the breakdown torque??
3. If I choose a motor which has a base speed of 1750 rpm, how much faster can I increase the motor speed using VFD in general?
4. When sizing a motor, what parameters do I need look at? make sure that
a: the motor starting torque is big enough to overcome the inertia (motor breakdown torque > system starting torque)
b: the motor full-load torque is bigger the maximum system running torque at 180 rpm? anything else?
5. What about speed? If I make sure that the torque requirements at the top running speed is ok, then I can assume that the motor can always run the system at lower speed using VFD, right?
Thank you very much!
Lee
Lee
