rmarotta
- Mar 23, 2003
- 17
Gentlemen,
I have a vfd that I'd like to use on a machine that requires a certain range of power to move material.
Hopefully, this vfd will replace several components. (A reversing contactor, soft starter, and a non-functioning load detector.)
Variable speed is not a primary requirement, but can I get a control signal from the drive that will allow me to externally adjust for load on the motor within certain limits, ie. 20-40% of nameplate KW. (2HP)
As I understand it, sensing power used by the motor should reflect the true load, regardless of varying levels of voltage or amps.
Any simple ideas for how I can get contact closures at the minumum and maximum power settings would be appreciated.
Ralph Marotta
Ralph Marotta
