Most useful mapkeys
  • Thread starter Thread starter SW
  • Start date Start date
S
SW
Guest
I know this has been discussed before but I thought it would be useful to compile a list of particularly useful mapkeys. A list of all the mapkeys you use is not very useful, but just the ones you think make a lot of difference.
I find the following extremely useful as I can quickly select and change features within
assembly mode without moving my mouse half way across the screen and
back.
SS for Smart Selection Filter<br style="color: rgb(0, 0, 0); font-style: italic; font-weight: bold;">SQ for Quilt Selection Filter<br style="color: rgb(0, 0, 0); font-style: italic; font-weight: bold;">SG for Geometry Selection Filter<br style="color: rgb(0, 0, 255);">
The following keys are also starting to wear out:
ED: Edit definition<br style="color: rgb(0, 0, 255);">ER: Edit references (without rolling back the features)<br style="color: rgb(0, 0, 255);">DE: Dynamic edit
Are also good.
If you have any more suggestions, maybe post them in the same format as above to make referencing them easier.
Sam
Edited by: SW
Maybe everyone isn't stuck with a 19" monitor like I am, but if you are this works well for me. If you have a mouse with programmable buttons, set on of the buttons to something like F11. then put this in your config.pro
mapkey $f11 ~ Activate `main_dlg_cur` `resizer_button_1`1;
It toggles the model tree....really handy if you don't have a large monitor.
I use PO for toggling preselection highlighting on/off. That is really
helpful in assemblies.
po @MAPKEY_LABELPreselection Highlighting On/Off;\
~ Activate `main_dlg_cur` `psh_sel_filter`;\
~ Activate `selprefs` `PrehButton`;~ Activate `selprefs` `Ok`;
I remember 19" monitors, last had one in the mid '90's.
I'm thinking my 26" is getting too small.
Can I have your 26 to replace my dual 19's?
When I get a 30" it's all yours.
SF Select Features
SA Select Annotations
These are all based on the Order of Selection list
1, 2, 3, 4, 5 so SF,SG in Sketch or Assembly will select something else for mine I use "x?" for drawings and "q?" for Assembly selections or anything else.
DA Display Axes
DC Display Csys
DD Display Datums
DX Display Points
DT Datum Toggle
GA taGs Axes
GC taGs Csys
GD taGs Datums
GX taGs Points
GG taGs Toggle
TP Toggle Panel - Model Tree
TB Toggle Browser
0o Options
0c Customize Screen
0s System Colors
etc.
Michael
Edited by: mjcole_ptc
I have one called LDS, it strips the part of all its layers and creates our layers. Then it puts all the features on to their repective layer (i.e. axes, csys, planes, planes GDT...) It comes in handy sometimes especially with external data or bringing legacy data up to date.
30" monitor
, I'd be happy to upgrade my dual 19s for a set of 24s. I remember the days of a single monitor, I don't think I could go back to that.
A few of my favorites -
q- Change smart filter to quilt
a- Change smart filter to geometry
z- Change smart filter to smart
era - edit-resume-all
rfv - insert mode
F1 Toggle base planes
F2 Toggle aux planes
F3 Toggle pnt/axes/csys
F4 Toggle surfaces
F5 Toggle solids
F6 Toggle curves
F7 Add quilts to layer
F8 Extrude surf
F9 Through all
F10 Revolve surf
F11 Draft check solid
F12 Save and close
Here's a list of the mapkeys in my vonfig. I actaully use most of them quite a lot...
< http-equiv="Content-" content="text/; charset=utf-8">< name="ProgId" content="Word.">< name="Generator" content="Microsoft Word 11">< name="Originator" content="Microsoft Word 11">
Actions
Regenerate
(automatic) rr
Repaint rp
Hide selected component aa
Show selected component ee
Show all components ae
Applications
Application
mechanism am
Application
Animation an
Application
Standard as
Construction
Insert mode ein
Select
parent of selected el
component
Create publish geometry pb
Insert external copygeometry ke
Cross Sections
Deactivate cross section xx
Activate
cross section A xa
Activate cross section B xb
Activate cross section C xc
Activate cross section D xd
Flip cross section xu
Data exchange
Export drawing to .ps pdf
Export drawing to .dxf dxf
Display Anzeige
Toggle component transparency tr
Shade component sc
Wireframe component dr
High quality display settings hq
Low quality
display settings lq
Toggle show edges kan
Toggle show silhouette edges sil
Activate Master Style st
Show all reference elements <<
Hide all reference elements >>
Drawing
Add (2x) to dimension 2x
Insert break in leader eu
Insert diameter symbol dm
Show M for
thread instead of gew
diameter symbol
Flip dimension arrows pp
Remove tolerance of txx
selected
dimension
Set tolerance of selected t01
dimension to
+/-0.01
Set tolerance of selected t02
dimension to
+/-0.02
Set tolerance of selected t05
dimension to
+/-0.05
Set tolerance of selected t10
dimension to
+/-0.1
Update table with repeat regions ta
Hide selected dimension ww
Family Tables
Family Table Dialog ft
Verify Family Table fv
File Operations
Open assembly oa
Open Drawing od
Open part op
Open generic part for og
active family
table variant .
Open drawing for active oz
part or assembly
Layers
Show layers
with reference elements fb
Show all layers fe
Hide all layers fa
Restore saved layer status fz
Measuring
Measure
distance ma
Measure
distance mm
Measure
diameter md
Measure
surface area mf
Measure
angle mw
Measure from
plane me
Measure pair distance mp
Sketcher
Sketcher references dialog ref
Exit sketcher without zz
saving changes
Orient sketch to sketch plane sp
Orient
I have a handful of mapkeys that I find useful but to be honest, I have been using them less and less as WF incorporates more selections with the right mouse button or with better icons.
Back in the pre WF days, certain actions definitely took a long time to complete but much of that has been improved.
I will say that all the mapkeys I use are left hand only so I don't have to take my right hand off the mouse. left hand only makes sense but also limits the keys you have available to use!
Zestje how do you accomplish this mapkey:
part or assembly
I come from an Autocad background, and the right hand on the
mouse with the left hand on the keyboard (or the other way round if
you are that way inclined) is extremely quick. Autocad works better
for this as the command waits for confirmation by hitting the
spacebar with the thumb, so multiple commands can start with the
same letter. Even the right-click options can't beat this for speed.
Sam
@copyboy: I have written an external script with AutoIt, whichretrieves the name of the drawing and opens the part/assy with the same name in ProE.
If you want to I can send it...
I also have a script to open the generic part when you have an instance open.
One of these operations is now implemented in WF5. I don't remember which one is.
Edited by: Zestje
I have a bunch of company mapkeys that I've created to helps us. Some of the most useful are the display mapkeys that quickly turn on or off items that are buried deep in other dialogs. I've placed them in a drop down menu, along with other display related comands:
Personally, I have mapkeys assigned to my function keys. Most of these came from my boss from the first company where I learned Pro/E, btu I still use tehm today. In fact, when I go to another user's computer to troubleshoot an issue, I find myself hitting F3 to repaint or F4 to reset the view and wondering why they don't work. Here's the list:
<div style="margin-left: 40px;">F1 Temporary Shade
F2 Default ViewF3 Repaint ScreenF4 Reset viewF5 Toggle Pre-highlighting
F6 Zoom Window
F7 Zoom PreviousF8 Saved ViewsF9 Top View
F10 Bottom View
F11 Front ViewF12 Right View
</div>
The items in bold are the ones I use all the time.
<DIV style="MARGIN-LEFT: 40px">F1 Temporary Shade
F2 Default View<BR style="FONT-WEIGHT: bold">F3 Repaint Screen<BR style="FONT-WEIGHT: bold">F4 Reset view<BR style="FONT-WEIGHT: bold">F5 Toggle Pre-highlighting
F6 Zoom Window
F7 Zoom Previous<BR style="FONT-WEIGHT: bold">F8 Saved Views<BR style="FONT-WEIGHT: bold">F9 Top View
F10 Bottom View
F11 Front View<BR style="FONT-WEIGHT: bold">F12 Right View
</DIV>
How do you create the custom menu?
RMB on any toolbar, select comnds and it's in the customize screen dialog:
Hello Zestje.
Can you explain it?
"Important: The script needs the Windows environment variable LANG to be set."
Thanks from Brazil.
@<a style="font-weight: bold;" name="178399"></a>
mwsivier:In Windows an environment variable is set or can be set to define the language. The scripts reads this variable to determine which search string to look for to determine which file to open. At the moment the script works with german, English and Italian langauge, but I'm working on making it ProE dependent only (if that is possible).
The 'lang' variable is set in control panel > sytem > advanced > environment variables.
