Flew to an offshore platform to meet a workboat that was going to do some soil survey work for a pipeline that we were to install in the GOM. It was November and the first front of late fall was crossing the coast bringing winds of about 40 mph. After closing in on the platform and negotiating the approach around the crane and over to the helipad and through the high gusts, the pilot managed to land and let me out without any major incident other than a few wild changes in direction. As he quickly flew off, I checked in with the two guys that lived out there and waited for the workboat to arrive. After several hours dusk came without any sign of the workboat. Then darkness as I negotiated for a place to sleep for the night. Bedded down on the sofa in the break room after a couple of dogs and a can of beans. The wind picked up and for some reason a number of instruments began to become sensitive to the wind and sounded the alarms and shut-in the platform 4 or 5 times during the night, so I didn't sleep hardly at all. If I had slept enough to have some common sense left by morning, I probably would have called the whole thing off, as the wind continued gusty, now colder and the waves had picked up to 2.5 meters.
About 9AM the workboat finally arrived 18 hours late and I had to figure some way to make a transfer aboard. The platform operators told me the basket drop from the crane was out of the question due to the high winds. I should have clued on that, but directed the workboat to approach in reverse from the downwind side towards the boat landing, figuring that I could use the wind to give me some extra momentum during a swing-aboard via the Tarzan ropes. The 2.5 meter waves wern't hitting the workboat at a good angle as he backed towards the boatlanding and a big one came by and broke over the stern sending water awash the aft deck and knocking down the two deckhands that were stationed to help me aboard, so he veered off of that attempt.
The only other alternative was from the boatlanding on the opposite corner of the platform, so we set up for an attempt from that corner. The winds wern't from a good angle, but the waves although high were negotiable for the boat, so I moved over to that corner and untied the Tarzan rope. About the same time, I noticed that the waves were going to be a major problem, since at those heights there was going to be considerable variation in the elevation of target zero between the time I left the boat landing and the time I arrived at the boat itself. It would require pretty good timing to reach my destination at the same time the deck rose to the correct elevation. OK, 1, 2, 3 swing... Wind caught me and froze me in mid air before blowing me back to the platform where a large wave made the return to the boatlanding as difficult as it could possibly make it. I tried again with the same result. It was going to be more difficult than I thought. I had to plan the swing better, so waited for the wind gusts to slow. Third time the gusts slowed down a bit and I managed to reach a full arc. It looked pretty good, until the workboat's deck started to rise a bit toooo fast. Still coming up and reaching mid swing. Getting closer to the workboat now and the boat railing was ... argh! right at face elevation. A split second later I was reaching the end of the arc just in time to slam into the side of the hull just below the kick plate of the deck. Impacting at full force of both me and the boat, the two deckhands grabbed me. I wasn't sure that was a good idea at the time, as then I had to let go of the rope, but once forcibly committed by their hands, I had no choice but to proceed aborard and released the rope with one hand as the other grabbed the boat railing, then finally letting go of the rope with the other. The two deckhands pulled me over the railing and onto the deck, just in time for all of us to get hit by another white cap as the boat went down below the trough. All of us went like flopping fish along the deck into the railing on the other side of the boat. As the water finally drained off when the boat climbed up the other side of the wave, we found ourselves by the engine room stairway hatch and quickly got it open and threw ourselves inside with the loud bang of the door slamming shut by itself. We took advantage of that and very quickly secured the latches happy at last to be out of the action and near the warm engine exhaust pipes. To this day I can't tell you why I even tried to make that transfer. I really should have called the whole thing off. So, I'd say there are two morals to this story, 1. get some sleep before you have to make an important decision and, 2. even though you feel responsibility towards carrying on with your work, don't let that idea overpower your common sense. Supposedly they don't pay you to be stupid. Could have very easily turned out to be at least three drown rats that morning.
"If everything seems under control, you're just not moving fast enough."
- Mario Andretti- When asked about transient hydraulics
