I need a low voltage (<10v) battery to run a small motor. The thing is, i need this battery to power the motor as consistently as possible, and I'm wondering what type of battery I should get. From what I understand, I want a battery with a very flat discharge curve, which is either going to be a NiCd, LiPo, or LiFe, but I dont want the memory on a NiCd. So which has a flatter discharge curve, a LiFe or a LiPo? Also, because the motor is fairly low current, and from what I've seen the discharge curve becomes flatter as the C of the discharge becomes greater, so does this mean that I want a lower capacity battery? Any ideas? Thanks.
