I would be very cautious of applying the 65% estimation factor these days. I don't know where your get your cement, but the powders today are ground so finely that it is more likely that you are getting as much as 95% of the 28 day strength at 7 days. Many of these estimations are based on coarser ground cements that hydrated much more slowly than the cements of today. And of course, the addition of slag, fly ash and or silica fume will all have an effect on the rate of strength gain.
If by cubes you refer to mortar cubes that are 50mm in dimension, the cubes are usually made using a standard (Ottawa) sand whereas the cylinders use job mix aggregates. Too many variables for accurate prediction.
If you are referring to concrete cubes used in Great Britain for example, I would assume that a correlation could be established.
If you are looking for a way to reduce test specimen size, use the 100mm x 200mm cylinders - correlations do exist and have been published. The best way is to develop your own correlation curves, though.
