Finally making some progress in the vacuum formed part I mentioned in thread562-258988.
I have an external shape for the base part but I'm having trouble thin walling it to the correct thickness. I need .125 and can only get .068. I get the error message "Thinwall failed. The faces contain a curvature which is smaller than the offset distance" which would be fine but the radii are a lot bigger than the thickness.
Any ideas?
Rather than a thinwall do you think creating an inner surface would be more successful and doing a boolean?
I'd post the model but it was too big when I tried before. Here's a jpeg though.
Any help appreciated.
Any ideas?
