HI Everyone,
I received a phone call from my Boss last night and he needed the formula for power. OK, easy enough. However, he told me of how he had his pool filter motor changed over ($190.00) to 220V instead of 110V he was using. My math says the power consumption is ALMOST the same. EG) 110V @ 12.7 amps as opposed to 220V @ 6.3amps. 100mA less than half on the higher voltage. His father, a retired linesman, believes 220V will save money due to reduced power consumption. I have also heard that running at the higher voltages (if the motor is capable) is more cost efficient. Is any of this true? And where is the mathematical equation I should be using to determine this if it is true?
Or is it going to take 179 years to break even on the original cost of the change? If so, I will post his email address and you can tell him
Thanks,
Scott
In a hundred years, it isn't going to matter anyway.
Thanks,
Scott
