Anchor block? Do you have a welded pipeline, or are you using bell & spigot joints? Or maybe you work in the Mideast, as they are known for their fondness of anchor blocks. If not, chances are you have a nice, big and useless, anchor block. Find a pipe stress engineer that knows how to do an analysis without sticking in anchors just because Caesar needs them to do the math. An anchor block does not remove stress, and in fact it only increases the stress in the pipeline, since elongation totally restrained. We know that total restraint at some point in the pipe always happens, at least in normal pipelines, because we do not see getting up out of the ground and walking off to Riyadh. So that means that an anchor block only localizes the point of full anchorment to a known position. Otherwise it happens at a virtual anchor made up of a long cylinder of soil surrounding the pipeline. What changes then? Only the rate at which the pipeline de-stresses itself as it exits the ground. An isolation joint anywhere in that area isn't the best idea. It either has to cope with high stresses or large rotations and deflections of the pipeline as it goes from anchor point to launcher / receiver. Search this website for numerous comments about removing these useless and costly anchor block accessories.
