I'm trying to find out the root reason why Detroit Diesel two stroke engines require, to this day, mono-grade engine oil, normally straight 40 weight. Empirical evidience, supported by recommendations from DD, is that the engines last longer between rebuilds using straight weight oil in normal service. I just don't understand why. what is there about a two stroke application that would make a multi-grade oil, of completely modern and high quality manufacture, less protective in this application?
The "common knowledge" answer seems to be that multi-grades revert to their cold viscosity under the pressure of two stroke compression cycles, that the hydrodynamic layer of oil in the bearings can't recover between power strokes, or that the long-chain molecules used in viscosity modifiers shear and break down. I just have a hard time lend credence to how a two stroke diesel, with 18:1 compression, running at 2100 rpm is that different from some other high duty engine requirement.
Any ideas?
Thanks for looking, Brian
Any ideas?
