Hi Again..
I have additional questions regarding the new code.
LADBS Interim Bulletin, "Method for distribution of lateral forces in wood frame buildings assuming flexible diaphragm", it says that diaphragm can be assumed flexible by complying some listed conditions, one of which is the shear panel and holdowns shall be designed to exceed the design load by at least 20%.This bulleting is referenced to the older code.
There are no latest interim reports published by LADBS yet on their website regarding this issue. But on ASCE 7-05 section 12.3.1.1, Diaphragms of wood structural panels or untopped steel decks in one-and two family residential buildings of light frame construction shall also be permitted to be idealized as flexible. Section 1613.6 of IBC 2006 also added conditions for assuming flexible diaphragms. No mention of 20% increase.
Can we can disregard 20% increase on two storey residential building for assuming flexible diaphragm on light frame construction and also for buildings having rigid analysis calculations?
Thanks,
Noel
