I am looking at trying to detect water leaking from coolers around a furnace by measuring the moisture content of the gas between the metal casing of the furnace and the first layer of refractory brickwork.
Currently a combination of thermocouples and H2 monitoring is used to indicate leaking coolers but I was hoping to install something at a point where I know we always get problems to try and detect leaks earlier, or at least use it as well as the H2 and temp readings as another confirmation of a potential problem.
At the point I am looking to sample from, the furnace casing temp is around 40 degs c and is constantly sprayed with water (the coolers are further up the stack and fitted internally). The gas at this point is mainly a mix of CO and CO2 at a temp of around (I would guess) 50 to 80 degs c, and at a pressure of around 1.5 bar.
Ideally the unit will screw into a weld on socket and give a 4 to 20 mA o/p to go to our existing I/O. I am against running a sample line from the sample point to a remote instrument as this would increase the chance of leaks and create further problems.
Any comments/advice would be gratefully received.
