Modify JT_Body in NX Part
Techomick
46
When I open and extract a JT file in NX8.5 it shows a single body "JT_BODY(0)". But this file consists of many seperate sheets. I can export the file to a STP and then reimport and then I can see the separate sheets, but is this possible to do without exporting and reimporting.
Essentially, I just want to be able to modify a JT_BODY.
Design Engineer, NX 7.5
File > Properties — JT File tab
Extract Exact Data
Loads the B-rep data from the JT files to change your model from facets to detailed solid bodies. You can create associative references, such as WAVE links and mating constraints, to these detailed solid bodies.
Thanks,
Mathi K
