Hi all,
I'm working on steel structure building restoration and change of use, and facing the following situation:
The existing open web steel joists (22H6) are not good to carry the new live load and I have to add steel beam in the middle to cut the span. please see sketch.
My question, these joist are supported by the top chord and I'm installing the beam under the bottom chord, is a double angle sufficient to support the top chord at the beam location as shown on the sketch.
Your response and suggestions much appreciated.
