hi all,
regarding the modifiers to apply to walls, I assign 0.7 to f22 for walls and then check the stresses using P/A + Mv/I to see if there is any tension area. if the tension stresses are higher than the modulus of rupture(generally in the upper stories where axial force is less) , 0.35 is assigned for f22 and drift(if any) is checked.
Any comments ?
Any comments ?
