blueandwhiteg3
Computer
I'm trying to work out the thermal conductivity of a vacuum. It is proving surprisingly problematic.
The theory is this: pressure has very little impact on the thermal conductivity of air. Thus, the intensive measurement of thermal conductivity does not vary with pressure. However, in terms of extensive properties, thermal conductivity in a large space of vacuum/near vacuum begins to drop with pressure due to the kinetic nature of gases. I believe this is around 10-15 pascals where this becomes notable for air.
However, I'm stuck at solving the math. I am looking to construct essentially a panel, one side will be hot, the other will be cold. I wish to use a vacuum to enhance the insulating properties of this space.
I want to model my panel's vacuum space thermal conductivity at varying thicknesses and varying pressures. From here, I can determine what is most appropriate for my application.
There will be no special gases or chemicals involved. Temperature range is 250-300 K typically. It's not rocket science, I just don't have the right math
Can anybody help?
Can anybody help?
