Modeling space aliens
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
hey fellow pro/e users!
I'm trying as hard as possible to draw a creepy space alien without the use of Rhino, 3d viz, Bryce, etc... I wanna do it in Pro/E... any suggestions on the easiest way?
I would use Isdx if you have it. If not use freeform surface, its under advanced depending which rev youre using.
Mike
I have try that but in style
Normally you can
You can do it in earlier versions of pro, you just have to plan ahead because it wont be as easy to tweak when you are done and it will take much longer.
Try building it up with datum curves first (without surfaces) and see if it is even close to what you intend.
Mike
