Modeling Reed Valves in GT Power
nickrakovec
1
I'm working on a two-stroke diesel engine model in GT-Power and I'm trying to look at different cases of controlling EGR. One method I want to look at is using a reed valve to drive the EGR and possibly control the EGR rate. I know that this is done commercially in some cases but I'm not that familiar with these types of reed valves. GT-Power has a "ValveReed" component, but there is a lot of user defined parameters where I'm not sure what value to enter. One problem is that I don't have access to any commercial reed valve suppliers to get data from a real reed valve to model. Does anyone have any advice on how to use this component or information on actual reed valve specifications? Thanks!
Nick, who'll take care of the dyno while you're modelling?
Either talk to Brian or can you populate the neccesary parameters of the generic reed valve in GT Power using Blairs book?
He talks a fair bit about them.
BTW a reed valve isn't a particularly durable component for a commercial truck application such as a Volvo or even a Fairbanks engine.
You could ask Aby but he's more than likely busy in the shop on his Mitsubishi.
Tke care
Sideways To Victory!
