Chandan321
Hi Guys,
I am trying to analyse and design a steel 3D frame structure 9m wide x 30 m high x 52m long. The transverse frames are at 13m spacing. There are beams at 3 elevations. The end frames along the longitudinal direction are braced at all elevations. The transverse direction wind is supported by adjacent building.
The steel columns rest on concrete pedestals. In the modeling software (STAAD), the columns and the bracings meet at the common joint with the concrete pedestals. I released the moments at the bottom end of the steel column, and the bracings are defined as trusses.
---- Now for the base plate design, do I take the member-end-forces at the bottom end of the steel member, or at the upper end of the concrete pedestals. I think that if I take the bottom end forces of the steel column, then i will miss out on the forces carried by the bracings to the base plate.
---- Else, do I connect the bracings to the steel column at some distance above the connnection with the base plate, and then take the member forces at the bottom end of the steel column at the joint with the base plate for the design of the base plate.
