hi,
I am trying to model the plastification in a railway wheel. My model consists of a rail(elastic) approximately 60mm length, a section(slice from a cake) of a wheel(plastic) .. approximately 5.5°. Now i want to perform a repeated process of rolling this wheel on the rail, ie. the wheel rolls and then is taken back to its origingal position, again rolls and again is taken back to the original position, I dont want any interaction between the wheel and the rail while the wheel is going back to its starting position. The only way i can think of is to raise the wheel vertically to some height(so as it looses contact with the rail) then translate it backwards and again put it down, it will work but sounds too complicated and long process!!! is there any shorter and more decent way of dealing with such problem. ABACUS/STANDARD Analysis!
