modeling membrane
cspkumar
34
I am modeling a triangular membrane. Tensile loads are acting at the three vertices inorder to keep the membrane in tension always.
Now, How do I model constraints for this problem? Because if the loads are in XY plane, there should be a x and y constraint somewhere in the model.
Kumar
Look for symmetry in your model and only model that part that is symmetric. Apply symmetry restraints to those free edges on the symmetry line and a single load to one point. If the symmetry goes through that load point remember to only apply half the load.
If you can't think of a symmetry plane then you will need to restrain at least two points to prevent rotation and at least one node to prevent translation. Your forces must balance for a static solution so fix one of your loaded points in the x or y direction. Fix another of the loaded points in either the y or x direction and apply the component of the required forces opposite to the restraint at those 2 nodes, ie if you fixed one node in the x then apply the component Fy at that node. You should find that the reaction forces will equate to the missing component force, hopefully.
