D
DrWily55
Guest
I am a long time pro/e user, but I have never attempted to use if for something like a house, or home re-building project. Has anyone done this, and what did you find that worked and didn't work.
As an example I built a framed wall from 2x4 studs (not seperate in this case) that are on 16 inch centers. Then relations to control the pattern (number of studs needed) by the length of the shoe. I then assembled the frame to the structure, did a cutout for the door and then assembled the door, which was modeled seperate.
Anyone have any suggestions or have done this before. It seems (without a long winded explanation) the best way to do it is creating parts and assembling each and every piece. Like 10 gazillon 2x4s. Is that how anyone else has done it?
Thanks in advance.
Thanks in advance.
