ModelCheck: Multi- Cond. in .mcc file
  • Thread starter Thread starter Francisdt
  • Start date Start date
F
Francisdt
Guest
I want to have a condition where two parameters must be met to point @ specific check files - Lifecycle statu and Units. So I can have different checks in work vs. release, and of course different checks between IN and MM
This is my attempt and with direction from PTC Support, but I don't see anything show up in the interface?
#Lifecycle States INCH
IF ( PTC_WM_LIFECYCLE EQ Basic ) AND ( MODEL_UNIT EQ INCH )
config=(check/basic_check.mch)(start/basic_start.mcs)(consta nt/inch.mcn)(status/basic_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Release) AND ( MODEL_UNIT EQ INCH )
config=(check/release_check.mch)(start/release_start.mcs)(co nstant/inch.mcn)(status/release_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Approval) AND ( MODEL_UNIT EQ INCH )
config=(check/approval_check.mch)(start/approval_start.mcs)( constant/inch.mcn)(status/approval_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Review ) AND ( MODEL_UNIT EQ INCH )
config=(check/review_check.mch)(start/review_start.mcs)(cons tant/inch.mcn)(status/review_status.mcq)
#Lifecycle States MM
IF ( PTC_WM_LIFECYCLE EQ Basic) AND ( MODEL_UNIT EQ MM )
config=(check/basic_check.mch)(start/basic_start.mcs)(consta nt/mm.mcn)(status/basic_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Release) AND ( MODEL_UNIT EQ MM )
config=(check/release_check.mch)(start/release_start.mcs)(co nstant/mm.mcn)(status/release_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Approval) AND ( MODEL_UNIT EQ MM )
config=(check/approval_check.mch)(start/approval_start.mcs)( constant/mm.mcn)(status/approval_status.mcq)
IF ( PTC_WM_LIFECYCLE EQ Review ) AND ( MODEL_UNIT EQ MM )
config=(check/review_check.mch)(start/review_start.mcs)(cons tant/mm.mcn)(status/review_status.mcq)
ELSE set the fallback (CADDocument OIR - LifeCycle Name at
Container level)
Edited by: Francisdt
