MODEL PLAYER NOT WORKING PROPERLY
  • Thread starter Thread starter tarundeep
  • Start date Start date
T
tarundeep
Guest
When I make a new model file the very first features i.e default datum CSYS,Planes fail to regenerate and there is message that
:Model has no modified items.
1. How can I rectify this mistake as it has sth to do with config file I suppose so that next time there is no such problem?
This is more important because I can't see the regeneration of my model from the very beginning because the first feature itselfs fails
Check the template (start part) you are using and see if the problem is there. If you fix that problem, you shouldn't have anymore trouble.
