We did the same thing a couple years ago, company-wide.
Lowering the model dimension definitely helped us with surface accuracy, and gave us better IGES and SLA output.
Back then, we noticed that some volumes and faces were corrupt due to curve accuracy. We quickly discovered that the 'bad' faces wouldn't shade. From there it was 'just' a matter of erasing the effected volumes and the 'bad' faces and all parent curves and then re-create everything with the tighter tolerances.
Maybe, with the current release of V4, this is no longer the case.
Good Luck!
