model appreance
  • Thread starter Thread starter slee_2k
  • Start date Start date
S
slee_2k
Guest
hi friends
ive designed a keypad for cell phone and i tried to apply material from texture Text and Numbers.but the numbers ive applied to the button surface larger than the size of button.does any one knows how to control the size of texture material .
hi
there is an option, in config.pro, in allows you to allocate a limit to texture size and control the resizing of texture maps that are used inside of PRO/ENGINEER graphics only. It has no effect in Photorender.
maximum_texture_size (set the value)
hope this helps
xcad
