hi
I have run a modal analysis for box assmbly using abaqus, i am getting 1st 5 modes on one of the plate are very low frequencies(in terms of 10s) where as if i run same plate without assmbly(single part with assembly constraint) i am getting mode frequencies in 100s (it seems to be correct theoritically). i am using same bc, matl prop and Mesh is fine. what could be the reason. mode shapes are matching. for assembly i have used fastener option in interactions.
