I was hoping someone could help me with the MMB concept. I understand VC and RC, but the respecting datum precedence for MMB has me a little confused and I don't feel like the standard does a great job in explaining this.
Scenario 1: Suppose you have a block with a call out of pin #1 with datum reference of position of .5 when established to A, B, C all at RMB. Another pin on the part defined with position of .3 and as Datum Feature C (pin#2) whose FCF is A, B(M).
For external features, would you just add the positional tolerance from pin 1 (.5) to MMC of pin #2 to get MMB and not consider the .3 from pin #2?
Scenario 2: What if pin #1 was now at A, B(M),C. Does that change the calculation?
Scenario 3 - you have multiple FOS callouts with DRF A, B(M). How do you select which features get incorporated into the calculation for MMB? Just the largest (most impactful) that would encompass all others?
Thanks in advance.
Thanks in advance.
