mjsamman
- Nov 22, 2008
- 22
Hi Dears,
We have a low pressure (LP) steam turbine (double flow). The last stage has 54 blades of ALSTOM made. We want to make feathering for 27 blades for the same row. 27 blades must be removed and install the feathered ones,alternatively.
My question is: Can we mix up between two blade manufactures such that 27 feathered blade is EthosEnergy made and 27 (not feathered) by ALSTOM made.
Is there any induced vibration or any significant problem for mixing up two manufactures in turbine blades?
