Dear Sir
I would like to ask a very trivial question.
Though the last post Already talked a lot about this issue.
By definition the specific gravity of gas can be calculated by
(1). the (MW of the test gas)/(MW reference gas), or
(2). the ratio of gas density at actual conditions to air density at standard condition
I tried to calculate mixed stream (mostly is hydrogen gas) specific gravity.
Condition is in the following :
The mixed stream gas density =18 kg/m3.
The mixed stream gas’s molecule weight =36
Gas molecule weight = 29
By method (1) 18 kg/m3 divided the gas density (1.3) can’t be equal to
Method (2) calculation result: 36/29
Thank you very much for your help.
