Mits 3015lvplus
laserman14
Alright here is on for you guys. Was working on laser yesterday when some how i turned my caps locks off. Laser won't read with it off. How do you turn it back on. Called mits they said the only way to turn it off and is with a keyboard plugged into the back side of the harddrive. But some how i turned it off with out it? Any ideas it did go back to caps locks when i rebooted the laser and the keyboard wouldn't work for some reason? Thanks Ryan
does your cnc controler have a window OS inside the mitsubishi software
I wait your answer
yes it does have windows on the machine windows 2000 i believe.
so if you can enter the windows "side" : follow
START / RUN / enter OSK / press VALID key
normally it appears the virtual keyboard
you just need to validate CAPS LOCK
excuse me for grammatical error
I don't speak and write a lot in english !!
the pooh
