P
phanna
Guest
I have recently returned to using Pro/Engineer after 2 years away from modelling, and am trying to use Pro/Mechanica after 3 years of not using it. The version is 2001 and it seems not dissimilar from what I had used previously. The problem is, I think there are elements missing from the installed software. When I switch to the Mechanica application, I can create constraints loads and some form of simple analyses, but run is not available unless I've created a mesh, and then I can only output to an Ansys, Nastran or Cosmos file. Results are never available.
Although we have purchased the software, we are no longer subscribing to PTC support and maintenance.
Any assistance or advice would be appreciated.
