Missing graphics window
CMcF
GB
My colleague can't see the window that shows the simulation model. We have dual monitors and are pluged in to Autodesk Inventor. Any ideas?
I am assuming you are using Workbench. If so I have experienced this problem before. The resolution was to use one of the menu options called "reset layout" or "reset views". I can't remember the exact term off hand. Anyway, it reset the layout of everything and I was able to see the model and tree again.
Hope this helps,
Steve
Stephen Seymour, PE
Seymour Engineering & Consulting Group
Thanks Steve,
we tried that but no use. It may be a network license issue.
