I'm facing a non-convergence with a strange characteristic:
after some equilibrium iterations, the Force Convergence Value tends to a constant value, higher than the Criterion of course.
The Workbench model is cyclically-symmetric, the cyclicity is enforced via CPCYC. It also contains surf-to-surf contacts and, unfortunately, also node-to-surface MPCs due to the presence of remote forces.
I suspect that the MPCs are not correctly handled in this cyclic analysis.
Have anyone of you already come across this kind of non-convergence?
Thanks in advance,
Thanks in advance,
