F
fazza
Guest
hi
does any one knows about these topics in pro e 2001
pls help
1. Family table can be created for Skeleton models?
2 How to create Skeleton.prt?
3. A graph view can be added in the drawing view?
4 Autocad drawing can be used for creating a layout.?
5. Cosmetic feature can be patterned using which of the following options. Tick which ever applicable.
Identical
Varying
General
6. Skeleton models can be created anywhere in the model tree.?
7. What is the use of envelopes ?
8 What is the difference between Quick fix and Fix model in the resolve Menu?
9. What are different types of dimensional pattern and the difference between them?
10. Cosmetic sketch can be erased by which method in drawing?
11. How can a layer be defined so that a particular feature type is only added to it automatically
12. After performing a File, Save As, what is the current object?
13. What is the difference between sketch point and Axis point.
14. If a drawing view is added with the
pls help
Identical
Varying
General
