mirroring of thickness, chamfer etc
  • Thread starter Thread starter shortcut
  • Start date Start date
S
shortcut
Guest
I need circular pattern of a body created via loft with thickness or chamfer commands. Chamfered or thickessed surfaces cant be patterned as expected. But Is there any way to pattern these solids? Thanks so much.
a circular pattern problem
I think my question was not clear. Loft + chamber cant be circular patterned. How can do it? Thankssss........
Move the loft, thickness and chamfer features into a new partbody that you assemble (boolean operation) into your part. Once your features are 'grouped' into their own part body, you can do a pattern (or mirror) based on the "current solid"
