Torque to fully loaded weight might be a better metric for anything resembling "normal driving". Include gearing if you want to be picky. Consider what happens to the potential acceleration when you add the same several hundred lb passenger load to both the Fiat and the SUV, or when you drive a Honda S2000 without getting within 1500 rpm of the VTEC switch-over point (relative to never dropping below it).
As for the lower limit on acceleration potential, that's a function of whatever minimum value will find sufficiently wide consumer acceptance. Reducing it below some vague point would probably involve psychological stuff and lots of consumer education - I suspect that most people don't care to use wide open throttle very often and would really hate to feel that they had to on a regular basis. And end up hating the car for it.
Greg has previously mentioned the ability to maintain speed on grades, to which I'll add coping with headwinds if a low maximum speed limited by power is selected.
Keep in mind for minimum top speed purposes (presumed reasonably achievable if set barely above normal posted speed limits) that the last few mph is added very slowly, as there is not much surplus torque available to accomplish the acceleration. The last mph could take over half a mile to add.
I'll have to bounce this topic off someone I know who drives an 18-wheel flatbed for a living (OTR) the next time he's in town, just to get thoughts from a different point of view.
Norm
