Please don't ask why I'm looking through the standard when it's nearly midnight, but... I'm hoping the other GD&T regulars on here can confirm a couple of minor things I've found in the 2009 standard. I'm not trying to nit-pick them (a job well done, I must say!), but here are three things that don't seem right:
1-- Figure 7-45 shows datum feature A with the new "CF" symbol. Is that usage OK? I guess the concept makes sense, but what bugs me is that "CF" is defined in paragraph 2.7.5 as only for features of size.
2-- Check out Figure 4-32. Is it kosher to show the 20 mm basic dimension and just assume that it is centered around datum A? I'm sure this question was in another thread many moons ago. I think most of us said that you should at least have one of the holes dimensioned as 10 mm from datum axis A.
3-- This last one's pretty tedious: Figures 5-2 and 5-3 describe straightness on a FOS this way: "the derived median line of the feature's actual local size must lie within..." The definition of derived median line in paragraph 1.3.31 says that it is formed by segments which are normal to the unrelated actual mating envelope. My question: Is there an internal conflict in those statements? The last sentence of 1.3.31 seems to throw a wrench into the idea of having straightness find the center points for each local cross-section. Heck, if we're checking the straightness based off of the AME, it will always be straight!
John-Paul Belanger
Geometric Learning Systems
John-Paul Belanger
