structural87
hello,
I would like to ask your opinions about torsional stiffness reduction for beams.
A lot of engineers use a low torsional constant (J = 0.1) in order for the beam torsional moment to be transmitted to the slab, in case of compatible torsional system.
however, despite assigning a low modifier to J, ACI recommends a minimum torsional moment (section 11.5.2.2) to abide by.
As such, torsional moment should be always be considered and can not be neglected in neither case (unless an interior beam with equal span and loading from both sides).
I am seeing a lot of engineers waiving this section and designing only for bending and shear (without any torsional consideration).
your thoughts please ?
thank you
thank you
