Is there a minimum time after manufacturing before a tire can be used?
I am thinking for example for a heavy duty van such as Daimler Sprinter. If I get a brand new set of tires (and the tires, almost literally, just made, for example only 3 days old), is it safe to be fitted on a van loaded (lets say, 3 tonnes)? Or is there a minimum number of days or weeks before these tires can be used?
The reason I ask is because after the tire is moulded, I am guessing that the rubber will still be undergoing chemical changes before it reaches some kind of "equilibrium" state. Because of these changes I am also guessing that the components of the tire (sidewall, carcass, etc) will not be all perfectly set and if the tire is suddenly submitted to high strains such as the van conditions above mentioned, then the tires will be permanently "damaged" and not have the expected performance?
Gerardo
Gerardo
