I was wondering if you know any criteria about the required minimum distance (straight line) between a regulator (actually a pressure-reducing valve) and a pressure safety valve?
I'm wondering because we are experiencing PSV chattering in a system where a PSV (set at 80 mbarg) is located 5D (D = line size, 2" in my case) after a pressure regulator, reducing pressure from 10000 mbarg (10 barg) to 50 mbarg. Seems that the cause of misoperation is the turbulence created by the regulator...
Any experiences? References for min. straighr line criteria?
Thanks.
"We don't believe things because they are true, things are true because we believe them."
Thanks.
