I was wondering if anyone had experience with ASME Section VIII Div 1 UG-135 (b)(1) and the minimum required pipe/fitting area between an ASME Section VIII Vessel and its thermal relief valve. UG-135 (b)(1) states:
The opening through all pipe, fittings and nonreclosing pressure relief device (if installed) between a pressure vessel and its pressure relief valve shall have at least the area of the pressure relief valve inlet.
The existing configuration that its being investigated is a short NPS 1/2 SCH 40 pipe (welded to the pressure vessel), 1/2"x3/4" NPT reducer and a 3/4"x1" NPT relief valve. The question around UG-135 (b)(1) is what the "area of the pressure relief valve inlet" refers to? Does this mean the relief valve should be no greater than a 1/2" inlet like NPS 1/2 SCH tank pipe? Or is this relief valve inlet area referring to the relief valve orifice diameter?
