Before making a selection, I would recommend calculating the
suction specific speed of the pump in question.
S = (N*(GPM^0.5))/(NPSHR^0.75)
*(N speed in RPM)
*(GPM at BEP, for double suction impeller divide total flow by 2)
*(NPSHR in feet)
Studies have shown that pumps with higher suction specific speeds have a much smaller window of reliable operation around their BEP. Depending on the guideline you are looking at, typical industry sources suggest S should be less than 11000 or 9000. Because you are looking at such a wide range of flows, I'd shoot for a pump with S less than 9000.
For a really high flow application like the one you are working on, it is quite difficult to find a pump with S < 9000 because you are fighting 2 parameters.
First, you need the NPSHR low enough so the pump does not cavitate. If you are restricted on suction head, your pump selection will be very difficult.
Second, the GPM is fixed, so you can vary the speed. A lower speed pump will be more reliable, but it will also be much larger, more expensive, take up more space, and more expensive to install.
The third factor you might be able to adjust is selecting a pump with a double suction impeller. This cuts the flow rate in half in the equation.
In any case, if you have a pump with a very high specific speed, at low flows it will likely have higher vibration, more internal recirculation (and the potential for recirculation cavitation damage), and long term it will have higher maintenance costs.
I've worked on a project with high suction specific speed pumps in the past (crude oil offloading pumps to a refinery). In this application, the high suction specific speed values definitely translated into sub-standard reliability.
Here is one reference.
Type "suction specific speed" into Google and you'll find plenty of others.
Also note, this should not be confused with "specific speed" which is a different topic entirely.
