The state rules have the following minimum pressure requirements on a public water system:
20 psi - Fire Flow + Peak Day Demand
30 psi - Peak Day Demand - 800 gpd/ERC
40 psi - Peak Instantaneous Demand
If I am looking at a commercial development, I am assuming to use the worst case scenario for my development's water system. So, I would use the 20 psi as my minimum pressure at the connection to the PWS. It doesn't make sense to me that I would be able to maintain that 20 psi to the rest of the development (if it is not all downhill/buildings above grade, etc.). What should I use as a minimum pressure to that development and buildings, if measured data is not available?
