sujins
Industrial
- Jun 30, 2005
- 31
1.Can any expert help explain, what is the minimum required flow rate of pump?
2.In the situation that we have to throttle the discharge flow because the rated flow is not at the intersection of pump curve and system curve(the rated flow is less than the flow at the intersected point, do we need to have the recirculation line to absorb for the excess flow rate?And do the system curve change after throtting of discharge control valve?
3. Does the recirculated flow rate in item 2 equal to the flow rate at the intersected point minus the flow rate at rated point?
4. The role of recirculation line and its meaning.???
