1
- #1
Hi all,
I am trying to calculate the minimum thickness of an exchanger tube under internal pressure. For this I am using ASME Section VIII Div 1. I am using an already designed piece of equipment to ensure that I am using the correct formulas. However I am bit confused as the ASME code is giving me a slightly different formula than the design calculation from the equipment.
I have uploaded the design calculation (document.pdf)
I redid the calculation using mathcad but this gives me a different min thickness than the design one (query.pdf)
And finally I did the calculation using the asme formula (asme.pdf)
I am not sure which formula to use here or if I am using the wrong code.
