Enhineyero
Structural codes have this criteria of minimum thickness of slab in relation to its unsupported length (like L/20, L/28, etc depending on support conditions). ACI says this does not apply to "members carrying partitions or other construction likely to be damaged by large deflections". Does this clause have a limit on applied live load?
Some engineers tend to use this to clause to justify a thin slab, and if the slab deflect too much they will point that "the code says we can use ____ thickness". say i have 10kPa as a live load, i dont think this clause will be applicable. does anyone have any insight on what live load limit can be applied to this criteria?
