JGoldstein
Gentlemen:
The drain sump of a tank has to be as small as possible, so that when the tank is completely drained, amount of sludge remained in the sump is minimum. On the other hand, if the drain sump is not deep enough, the suction line of a drain pump will start sucking air before the liquid in tank has dropped down to the top of the sump, and the suction will stop.
How the minimum drain tank depth can be determined to satisfy both conditions - minimum sump depth, but the pump will still drain the tank to the very top of a drain sump?
Thank you.
Thank you.
