Min and Max requirements for basemetal.
sftyvlv1
CA
Afternoon,
Is there a table in the ASME code that refers to min and max requirements for chemicals/alloys of base metals?
I was trying to compare the above with the MTR I have for this material, all I could find was a table for this grade of pipe and hard numbers.
The exception being Manganese had a range.
Thanks Dave
sftyvlv1, you should find everything you need in ASME Sec II, Parts A & B, including (somewhere) tolerances on composition. Keep in mind if no max (or min) is listed in the specs it does not apply.
Mike
In many ASME/ASTM specification, some elements will only have a maximum listed.
And if the element is not listed then it does not matter, unless it makes it into a different grade.
One caveat, The general specifications covering the materials may have additional limitations. For example SA-20 for CS materials and SA-480 for SS materials.
And now that I think of it there are some specs that say 'total of all others not to exceed xxx'.
So there are some odd ones out there.
